Only one tool usable at a time?
724
12-02-2025 03:05 PM
RogerAsbury
I've created a ribbon bar that allows for some location specific tools. One of those tools is a popup window allowing a user to enter a Latitude/Longitude coordinate and zoom to it or mark it on the map. When this window is open, if the user attempts to use one of the other items on the ribbon, they all grey out.
I'm curious what the procedure/code is to allow this tool to remain open while leaving the other tools still usable.
Code for the window is pretty basic:
<Window x:Class="FNSBArcGISProAddin.Tools.LatLonDialog"
        xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
        xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
        xmlns:local="clr-namespace:FNSBArcGISProAddin.Tools"
        mc:Ignorable="d"
        Title="Latitute Longitude Interface" Height="150" Width="330">
    <Grid Background="#FFFFE0C0">
        <TextBlock x:Name="txtLatLong" HorizontalAlignment="Left" Margin="10,10,0,0" TextWrapping="Wrap" Text="Latitude_________________________________________Longitude" VerticalAlignment="Top" Width="480"/>
        <TextBox x:Name="inputLat" HorizontalAlignment="Left" Margin="10,42,0,0" TextWrapping="Wrap" Text="TextBox" VerticalAlignment="Top" Width="143"/>
        <TextBox x:Name="inputLon" HorizontalAlignment="Left" Margin="174,42,0,0" TextWrapping="Wrap" Text="TextBox" VerticalAlignment="Top" Width="136"/>
        <Button x:Name="btnPan" Content="Pan To" Click="pan_Click" HorizontalAlignment="Left" Margin="10,79,0,0" VerticalAlignment="Top" Width="134"/>
        <Button x:Name="btnDisplay" Content="Display" Click="display_ClickAsync" HorizontalAlignment="Left" Margin="190,79,0,0" VerticalAlignment="Top" Width="120"/>
    </Grid>
</Window>
But you can see that if you click other button on the ribbon, they grey out:
Lat/Long interface w/greyed out buttons. :(Lat/Long interface w/greyed out buttons. 😞
Roger Asbury
Analyst/Programmer - Fairbanks North Star Borough
Tags (3)
GKmieliauskas
Your issue isn't in xaml. You open window as modal. Try open it as modeless
        private ProWindowMakeProFilters _prowindow = null;
        protected override void OnClick()
            //already open?
            if (_prowindow != null)
                return;
            _prowindow = new ProWindowMakeProFilters();
            _prowindow.Owner = FrameworkApplication.Current.MainWindow;
            _prowindow.Closed += (o, e) => { _prowindow = null; };
            _prowindow.Show();
            //uncomment for modal
            //_prowindow.ShowDialog();
GKmieliauskas
            //already open?
                return;
            _prowindow.Show();
RogerAsbury
Thanks much! That did the trick.
Roger Asbury
