MapView.Extent is wrong on spatial reference change
3784
8
06-08-2019 07:32 AM
MaxMax2
Code for test:
var sr = mapView.Map.SpatialReference;
var extent = mapView.Extent;‍‍
Steps to reproduce the problem:
1. Create new project. Variables now will have values:
2. Add layer with WGS84 spatial reference and zoom to full extent (the issue will be without zooming too). Now execute the code above:
We see that spatial reference now is WGS84, but extent coordinates doesn't correspond to WGS84. Max extent for this sr must be -180 -90 180 90 in degrees, but the values from screenshot are obviously wrong.
More than that I can't project extent to WGS84, because it's already in WGS84, so coordinates still the same!
CharlesMacleod
Max, the issue to me looks like you are not specifying a cell size. The resulting cell size of the raster is 10600614 which matches the dimension of the raster. I do not know the significance of that number (i.e. why is it used as the default cell size). However, if I do specify a cell size explicitly (eg "90" or "180" ) then the extent of the layer is correct (as, in, it is a proper extent).
As the cell size, in this case because of the projection being used, is in decimal degrees and the WGS projection is wider than it is tall, I assume that the maximum possible cell size will be "180" while still retaining a "real" spatial extent.
For example, using your same settings and a cell size of 180:
MaxMax2
Any news on this issue?
CharlesMacleod
I cannot reproduce. My results using 2.4:
SR Domain, MapView Extent, layer "QueryExtent"
Initial extent:
Zoom to layer extent
Pan to date line (or approx) with "Enable wrapping around the date line" enabled
layer properties:
map properties:
MaxMax2
Hi Charles,
I found exact scenario to reproduce issue. I suppose you added feature layer with WGS84 and all is OK. Yes, in this case I see valid values too.
But if I add raster dataset with WGS84 to new project, values will be invalid:
I've attached zip archive with GDB with raster dataset to my question.
Raster dataset created with this code:
var fullExtent = await QueuedTask.Run(() => EnvelopeBuilder.CreateEnvelope(-180, -90, 180, 90, SpatialReferences.WGS84));
var args = Geoprocessing.MakeValueArray(datastorePath, RasterDatasetName, null, "32_BIT_UNSIGNED", null, 1, null, "NONE");
var env = Geoprocessing.MakeEnvironmentArray(outputCoordinateSystem: SpatialReferences.WGS84, extent: fullExtent);
var gpResult = await Geoprocessing.ExecuteToolAsync("CreateRasterDataset_management", args, env, cancellationToken, flags: GPExecuteToolFlags.AddOutputsToMap);
CharlesMacleod
Hi Max, the layer extent looks bogus:
MaxMax2
OK, but it has been created with Create Raster Dataset tool, so dataset is created in legitimate way. Is it a bug in Create Raster Dataset geoprocessing tool? How can I create valid raster dataset in GDB?
MaxMax2
I've also checked Create Raster Dataset for GDB and file rasters, and in all cases output dataset has such strange extent. Please give advice how can I create valid raster dataset with valid extent for WGS84?
CharlesMacleod
MaxMax2
Thanks, that works! Quite strange behavior since cell size is optional parameter.
