How to target older versions of ArcPro with SDK?
452
10-28-2024 11:21 AM
PhilipBaileyUSU
Is it possible to develop an AddIn using ArcGIS Pro SDK for .Net version 3.3.0.52636 that can be used with older versions of ArcPro (specifically 3.1)? If so, how do I configure an AddIn to do this?
CharlesMacleod
this is not supported.
jeremywiles1981
I have a separate pc that I use for 3.2 builds. I need to keep .NET 6 in that project, and the extension's auto-update feature off.  I downloaded and installed the older 3.2 version of the SDK and keep it on 3.2 version, since it is not possible to downgrade the extension.
Hope this helps.
