How to listen for geoprocessing (GP) events?
2102
04-28-2021 05:44 AM
kirken
Is it possible to listen when user edits data by using some GP tool e.g . Calculate Field or Delete Field? I want to handle this event similarly when user modifies data in edit session and I'm listening for row events:
       protected void HookEvents()
            QueuedTask.Run(() =>
                //Listen for row events on a layer
                foreach (var layer in EditorIDLayers)
                    var layerTable = layer.GetTable();
                    _rowCreateToken = RowCreatedEvent.Subscribe(OnRowCreated, layerTable);
                    _rowChangedToken = RowChangedEvent.Subscribe(OnRowChanged, layerTable);
                    _rowDeleteToken = RowDeletedEvent.Subscribe(OnRowDeleted, layerTable);
protected void OnRowChanged(RowChangedEventArgs args)
            if (_lastEdit != args.Guid) //avoid recursion
                EditInfo edit = new EditInfo(args);
                edit.ModifyOperation();
                _lastEdit = args.Guid;
public EditInfo(RowChangedEventArgs rowEvent)
            _MainViewModel = EditorIDViewModel.GetVM();
            EditOp = rowEvent.Operation;
            ModifiedRow = rowEvent.Row;
 public void ModifyOperation()
            TableDefinition definition = ModifiedRow.GetTable().GetDefinition();
            var attributes = new Dictionary<string, object>();
            attributes.Add(settings.EditorField, _MainViewModel.UserName);
            attributes.Add(settings.DataSourceField, _MainViewModel.SelectedDatasource.Key.Item1);
            EditOp.Modify(ModifiedRow, attributes);
2 Solutions
NarelleChedzey
If the GP tool is run within an edit session then the row events should fire.  A GP tool will run in an edit session if there are existing pending edits or if you enable the 'Undo' in the gp tool pane.
This is true for the Calculate Field or Delete Rows tools.  but not for Copy, copy Rows, Copy Features etc which do not have the 'Enable undo' checkbox on the tool UI.
What type of data are you using - shapefile, file geodatabase, enterprise, feature service?
Narelle
NarelleChedzey
Try modifying the row using the row[fieldName] pattern.
private void OnRowChanged(RowChangedEventArgs args)
  var row = args.Row;
  var oid = row.GetObjectID();
  if (args.EditType == EditType.Change)
    row["Notes"] = "123";
Let me know if this doesn't work for you.
Narelle
NarelleChedzey
Narelle
kirken
Thanks for the response, Narelle. Yes, the row events fire when using GP tools within an edit session but strangely RowChangedEventArgs Guid is always {00000000-0000-0000-0000-000000000000} and if I try to use edit operation of RowChangedEventArgs:
it does not modify the record within row event. Nothing happens, except the changes of GP tool.
Don't know if my doing it wrong or it's a bug ?
I'm using file geodatabase and enterprise.
NarelleChedzey
  var row = args.Row;
Narelle
kirken
Thanks a lot !! 🙂 ✌️
It seems that I got everything working by removing EditOp.Modify() and using your example.
