How to get selected feature(s) from selection tool?
2451
6
10-11-2022 03:35 AM
OscarYam
I would like to create a button that updates the selected feature's attribute. When I started coding, I found that I cannot get the selected feature after I use the default selection tool(the tools under esri_mapping_selectToolPalette). Is it any method to get the selected feature from the default selection tool?
CharlesMacleod
Subscribe to the MapSelectionChangedEvent. Any changes to the map selection via selection tool, via custom selection, etc. will fire the event.
ArcGIS.Desktop.Mapping.Events.MapSelectionChangedEvent.Subscribe((args) => {
   //If u are only interested in one particular map...
   if (args.Map.Name == "The Map Name I am Interested In") {
     System.Diagnostics.Debug.WriteLine("Selection changed");
     var sel = args.Selection;//This is what is selected
     if (sel.Count == 0) {
       System.Diagnostics.Debug.WriteLine(" 0 features selected");
       return;
     //enumerate current selection - a series of keyvalue pairs
     //key is the MapMember, Value is the list of OIDs
     foreach(var kvp in sel.ToDictionary()) {
       var oids = kvp.Value; //OIDs of the selected features
       var oid_str_list = oids.Select(oid => oid.ToString()).ToList();
       var oid_str = string.Join(",", oid_str_list);
                     $"{kvp.Key.Name}: {oid_str}");
       if (kvp.Key is BasicFeatureLayer fl) {
         //TODO selection is on a vector layer...
       else if (kvp.Key is StandaloneTable tbl) {
         //TODO selection is on a table...
       //else if (....)
       //   etc,etc.
Note: In 2.x, the event argument syntax is slightly different. The Selection property is a Dictionary so there is no sel.ToDictionary() as such.
CharlesMacleod
       return;
       //else if (....)
       //   etc,etc.
OscarYam
Would you mind explaining more about where should these codes go to? Should those codes go to Module1.cs or the button.cs? I am using Arcgis pro 3.0.
CharlesMacleod
The Module is probably the best place. There is an initialize method in the Module which is probably a good spot. I would also set your module autoLoad attribute to true in the Config.daml.
 <modules>
    <insertModule id="...." className="Module1" autoLoad="true"
       caption="Module1">
internal class Module1 : Module {
  private static Module1 _this = null;
  protected override bool Initialize()
  	//TODO subscribe to the mapping event here
  	return true;
OscarYam
Thank you for your solution. Here is what I come up with to fit my situation.
I added the following code in module1.cs like you said. And created a class to store selections so I can access the selected features within my addin project.
	SubscribleMapSelectionChangedEvent();
	return base.Initialize();
private void SubscribleMapSelectionChangedEvent()
		if (args.Map.Name == "My map")
			#if DEBUG
			#endif
			if (sel.Count == 0)
				#if DEBUG
				#endif
				return;
			else
				CommonObject.GlobalVariables.SelectedFeatures = sel.ToDictionary();
CharlesMacleod
Nice work Oscar. One thing I thought I would mention: The module class is actually already global throughout the addin (by design). All classes can access it via the special "singleton" property called "Current".
Therefore, if you wanted, you could add a "SelectedFeatures" property to your module class directly and access it that way. So it could look something like this:
    private Dictionary<MapMember, List<long>> _selFeatures;
    //Any (non-private) module property or method can be accessed from
    //anywhere within the addin
    internal Dictionary<MapMember, List<long>> SelectedFeatures =>
     _selFeatures ??= new Dictionary<MapMember, List<long>>();
    //elsewhere...access the property via Module1.Current...
    foreach(var kvp in Module1.Current.SelectedFeatures) {
OscarYam
Thanks for your additional info, cheers!
