We are developing an application using ArcGIS Pro SDK 2.7 version.
One of the core requirement is to draw and edit Bezier curve with four control points .
Four points curve: In general we are able to draw a Bezier Curve with 4 points ( point 2 and point 3 will act as control points to adjust the curve.) as below screen -
As per our requirement we to draw a Bezier Curve with 4 points ( here point 2 and point 3 also should act a MapPoint but not the control points.) as below -
how can we calculate control points and draw Bezier Curve in ArcGIS PRO SDK.
Note - In ArcMAP using Arcobjects SDK we have a direct interface to create Bezier curve with 4 control points INEWBezierCurveFeedback interface , We are looking forward for relevant and same interface in ArcGIS PRO SDK.
Your inputs/ideas are most appreciated.
