Get Archive Table in ArcGIS Pro
2554
07-25-2017 12:11 AM
JoseSousa
How do I get access to the archive table associated with a feature class using the ArcGIS Pro SDK?
In the past we could access directly the archive table using the code below:
IArchivableClass archivableClass = table as IArchivableClass;
where table is an ITable.
I have a batch script coded in ArcObjects to abstract us from the underlying gdb schema changes that require conversion to the new SDK.
// This is my ArcGIS Pro feature class object
FeatureClass featureClass = geodatabase.OpenDataset<FeatureClass>("SDE.DBO.MyFeatureClass");
How can I get the archive table associated with this feature class directly?
Cheers,
Jose
Tags (1)
ColinZwicker
Jose,
Access to an archive class is on the road map, hopeful to have it for the next release of ArcGIS Pro's SDK.
Would would mind briefly describing what you then do with the archive class, what questions are you answering?
(this discussion can be taken offline if you feel more comfortable)
Colin
ColinZwicker
Jose,
Colin
JoseSousa
Hi Colin,
Thanks for replying and confirming that it is coming hopefully in the next release of the SDK.
Regarding your question it really depends on the organisation we are working with.
Examples:
- Integration between ArcGIS and SAP PO or SAP Gateway. Every CRUD operation must be kept in sync with SAP.
  There is a queuing mechanism for this. So we have scheduled tasks running nightly to move the deltas (and other
  additional information) back into SAP.
- Provide a way for third party systems to easily poll for updates that happened in GIS. Because the centralized archives
  are lost when you deactivate Archiving we keep track of the last 90 days deltas into a separate table which can then be   accessed via SQL or through REST/SOAP.
- Have custom services that provide to client apps access to historical data
As a side note, I hope that History (not just Archiving) is implemented throughout the platform soon. I believe many people including myself would be happy with this. Or maybe having the ability to restore the archive tables with the geodatabase once you re-enable Archiving.
Cheers,
Jose
