Dynamic loading of config.daml
1686
02-04-2020 11:18 PM
by Anonymous User
Not applicable
Hi ArcGIS pro sdk team,
Would like to explore some possibility of loading default config.daml file from module extension.
For example, in the extension I shall have config.daml, config.uat.daml, config.prod.daml.
If I would like to load daml accordingly , instead of config.daml, want to load config.prod.daml how can I easily do it or where can i interrupt the config.daml file loading?
Best Regards,
Than
UmaHarano
Hi!
Configurations allow the processing of DAML at Pro start-up.  The callback to use for this is OnUpdateDatabase  You can also use the OnCreateDAML callback in Configurations to provide DAML in the form of an XML string at run-time.
With Add-ins, you will have to modify the UI (at runtime) using states and conditions.
Thanks
Uma
by Anonymous User
Not applicable
Hi Uma,
Just double check, is that applicable for Module extension/addin as well?
As I noticed it seems to be only for configuration addin, addinx and I can't have daml several daml files to modify the custom module add-in from it as well. Refer to my previous question https://community.esri.com/thread/238888-arcgis-pro-sdk-proconfigx-config-project-cannot-modify-cust...
Moreover that will be very complicated if I have to modify by code in ProConcepts Configurations · Esri/arcgis-pro-sdk Wiki · GitHub  onupdatedatabase override as well.
So if sdk can support to modify the custom module from daml from config addin , If I just point relevant config.daml by using xmldocument object and return, that could be much cleaner.
