Disable the Add-In button on selection of one button
4091
6
06-17-2021 04:42 AM
TapasChakrabarty
I have my Add-In on ArcGIS Pro under which I have 4 buttons. So, now I want if I click on any button I want rest of the button get disabled. Until I close the current page.
ArcGIS Pro SDK 2.8 VS2019
KrisCulin
I think the easiest way to do this is to use the condition.  Set the condition in the config.daml file for your buttons.  Then in the code, you can control the state of the condition.  There are examples of how to do this in the AGP Wiki (a great resource to use as it answers A LOT of questions you might have).
Kris
TapasChakrabarty
Can you share any links?
KrisCulin
Here is the link to the ArcGIS Pro SDK wiki
Home · Esri/arcgis-pro-sdk Wiki · GitHub
Kris
Wolf
by Esri Regular Contributor
This Pro Guide (it's in the Wiki Kris mentioned above) shows how to make your own states & conditions:
ProGuide Code Your Own States and Conditions · Esri/arcgis-pro-sdk Wiki (github.com)
by Anonymous User
Not applicable
Hi @TapasChakrabarty ,
On top of states and conditions, you can use this code to enable/disable the button from the ribbon bar.
ProGuide Code Your Own States and Conditions · Esri/arcgis-pro-sdk Wiki · GitHub
FrameworkApplication.GetPlugInWrapper("your button id in daml").Enabled = false;
SANTIAGOPARDINIHERNANZ
Hi, thanks for this tip. In my use case,  this FrameworkApplication.GetPlugInWrapper("your button id in daml").Enabled = false; is complaining about being a read only property :(...  Any ideas?
Thanx in  advance!!
