CIMPolygonGraphic.Name not getting set?
1117
10-19-2022 10:43 AM
DanielRatzlaff
I apologize if this is a dumb question, I'm new.
I have a tool that allows a user to sketch a selection rectangle on a graphics layer, and I'm trying to set the Name property so I can refer to it again, but after adding the element to the layer, the Name property ends up being "Rectangle".  This code is in OnSketchCompleteAsync:
Polygon box = geometry as Polygon;
QueuedTask.Run(() =>
    var poly_symbol = SymbolFactory.Instance.ConstructPolygonSymbol(CIMColor.CreateRGBColor(130, 130, 130, 40));
    var graphic = new CIMPolygonGraphic()
        Symbol = poly_symbol.MakeSymbolReference(),
        Polygon = box,
        Name = "ExtentSelection"
    displayLayer.AddElement(graphic);
What am I doing wrong?
DanielRatzlaff
Sorry, I figured it out.  The Name needed to be set on the Element, not the CIMPolygonGraphic:
    Polygon = box
displayLayer.AddElement(graphic,"ExtentSelection");
GKmieliauskas
My code is a little bit different and it works on ArcGIS Pro 9.2
    Polygon = box
graphic.Name = "ExtentSelection";
It seems that CIMPolygonGraphic constructor overrides Name you set
