ArcGIS Server Interceptor TLS1.0 mscorlib error
1450
05-14-2020 06:15 AM
VictorTey
Hi, i have a SOE (server object interceptor) build using 2.4.0 sdk. Everythings works fine however when I disable TLS 1.0 via the registry
I get the error shown below.
This is my registry below which works if I set enabled to 1. Setting it to 0 will cause the error above. Am I doing something wrong?
The feature layer is published using ArcMAP (initially I tried ArcGIS Pro however it doesn't pick up the interceptor)
It is a requirement of our client to adhere to the security checklist below (one of which is to disable tls 1.0)
CIS Microsoft IIS Benchmarks
Any workaround is appreciated
VictorTey
Ok, I figured out the reason. My .net Framework is target at 4.6.1 which uses tls 1.0 by default.
Solution is to to add
System.Net.ServicePointManager.SecurityProtocol = System.Net.SecurityProtocolType.Tls12;
I also change my target framework to 4.6.2 which utilises tls 1.0 and 1.1 by default
VictorTey
