Work Around if I can't use Merge Branch (ModelBuilder)
557
05-23-2023 12:17 PM
C_McNamara
Hello!
I am trying to share a ModelBuilder to the web but I don't have a version that supports the "Merge Branch" logical tool. So my model has become much larger and still works for the most part. However, I now have 3 output results (see image). In reality two out three of these items will never exist in the model. A user selects a mode of travel as a parameter and then the model runs specifically for the mode and not the other two...
I've tried to only produce only 1 output_result but my model breaks down. I've tried the "merge" geoprocessing tool but that doesn't seem to work because the items its trying to merge don't exist. Does anybody know of a workaround for merge branch so I don't need to duplcate unnecessary output parameters in modelbuilder?
Thanks!
Colin
Here is my lovely model that I am quite proud with the merge branch
 And here is the monstrosity I have created in order to share this to the web to one day be a widget!
