Why is ArcGIS PRO so slow to cancel a simple geoprocessing tool ?
28446
45
07-19-2019 01:58 PM
JoabelBarbieri
Anything you try to cancel in ArcGIS PRO just gets hanging and spinning and it won't finish. It seems PRO tries to finish the process before cancelling which is a HUGE waste of time and resources. Having to kill the exe, losing all your work is a constant. ESRI must address this issue
Example where I canceled and it's spinning for MORE than 15 MINUTES !!!
Wayne_Rennick
@JoabelBarbieri Just wondering if you're still waiting for the process to cancel? I'm currently at 30-minutes to cancel a simple Clip Raster Geoprocess.
I just figured you've been here for about 5-years waiting for a reply from ESRI.... Maybe you have suggestions on good ways to pass the time.
JoabelBarbieri
Hahaha, unfortunately, I don't have good suggestions. I always have the task manager open and just kill the ArcGISPro.exe every time it hangs for more than 30 seconds to cancel.
I've also set my autosave parameters to 2 minutes (you can find that in Options>Application General> Project recovery) to avoid losing too much work if I have to kill the exe.
JoabelBarbieri
Not only it is still the same in 3.3, but now cancel adding data from Agol or Living Atlas (which takes forever by itself) is behaving the same
10+ minutes and still didn't cancel....
SarahSibbett
Hi everyone,
I'm currently at the user conference in San Diego and brought this topic up in a meeting with a few developers. What I learned is that geoprocessing tools are designed in a way that breaks the tool down into segments of work. Apparently, many geoprocessing tools are in fact configured in a way that they will cancel out if the user requests; however, before the tool cancels out, it has to complete the current segment it is on. If that segment of work takes a long time to complete, the tool takes a long time to cancel.
I got the name of a contact on the geoprocessing team, and I am going to try to track that person down today in order to get more information about this. Apparently, some tools may not be designed very well in how the segments of work are organized, so this issue may be tool specific. I will try to get a bit more info, or ask the developer himself to post a better and more detailed response than I have if has a chance to.
MeganBleess1
Go get 'em Sarah!  I wish I could be at the UC!
It seems that many tools have this issue and everything in Pro is called geoprocessing!
SarahSibbett
Me again.
I've learned that the reason the tool needs to complete the segment of work it is on before it cancels is because there is a risk to your data if it just stops in the middle of what it is doing - so essentially, at the end of each segment of work is a safe spot to cancel, without posing any risk to your data.
The issue is that each tool implements its own cancel logic and sometimes you won't have any cancel logic because the tool wasn't written well. The geoprocessing development team is trying to create a holistic cancel approach to resolve this inconsistency amongst geoprocessing tools, but it needs to be implemented in such a way that there is no risk to customer data. One method was tested, but it didn't work and had too many bugs. A new method is in the design phase.
I hope this information is helpful and provides a bit more context.
Wayne_Rennick
I appreciate you trying to get some answers from the developers. I'd love it if the developer/team would respond here.
It blows my mind how long it takes to import symbology from one layer to another in ArcGIS Pro. I have a beefy computer and it should take a second, not 30+ seconds. In my experience Pro does some geoprocessing faster than ArcMap (raster and vector analysis). I assume that's because it's able to use more memory and multithread. But most (all?) the basic cartography tools are glacial.
MichaelLedwith
Well, it’s small consolation to get a confirmation of what everyone stated at least three years ago.
We know that it hangs because the software is trying to complete the process. What we want to have however is a tool that can be stopped immediately without corrupting the data.
MetralAlexis
I've doubts about that explanation. I just canceled a Export Raster (a DTM from GDB to tif) <10MB and it's stuck. That's such a simple geoprocessing task, whish usually takes 15s but nope, I've to kill ArcGISPro in the task manager. Just assume that the Cancel option it completely useless and remove it form the software. I've no memories of it working properly.
UseItOrLoseIt
The explanation is also hugely problematic if it's true. What happens when the process itself is hung up, and that's why you need to cancel? It will never finish the segment it's working on if it's hung up; therefore, it will never be able to cancel. Brilliant!
