Weighted Sum: Unexpected error (999999)
7791
9
02-20-2022 08:17 AM
Labels (2)
emd55
Hello, I am trying to run the Weighted Sum tool and keep getting this error message:
ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
Failed to execute (Weighted Sum).
I'm using ArcGIS Pro 2.8.3 and Weighted Sum tool in Model Builder. Inputs are 5 raster datasets with Field assigned correctly and weights assigned.
Input files are saved on OneDrive; I suspect this may be the issue. I pause OneDrive syncing while running Arc Pro but when I try to copy the files to a local location to see if that helps, I run into other issues.
JayantaPoddar
Refrain from using Onedrive or Network drive for input/output parameters.
Ensure you are saving the output Raster inside a basic file folder in a local drive (C:\Myimages\wtsum.tif).
Save Output as TIFF (*.tif), if the error persists with Imagine extension (*.img).
Think Location
emd55
Thank you. I tried saving the output Raster inside a basic file folder in a local drive and as TIFF (still have inputs saved on OneDrive for now) and get the same error.
I am trying to copy and paste the input files from OneDrive to a local folder, using Catalog, and get the attached error
DanPatterson
MVP Esteemed Contributor
you have spaces and punctuation in your paths, skip catalog and move your files to a simple, clean folder using windows file explorer and try from there
... sort of retired...
emd55
Thank you! Working on that, little at a time because of space limitations
emd55
Moved everything currently being used to local folder, now trying to run the tool gives error:
None of the processes are ready to run.
KimberlyGarbade
When you ran a check on your model in model builder did it tell/show you were the model is broken?
emd55
Nope, it doesn't give any further details and when I 'validate' before running, nothing happens
by Anonymous User
Not applicable
Thanks for your questions. Could you share the data and repro steps of those errors with me? I will then look into it and get back to you as soon as I can.
emd55
Thank you! Just emailed you
