WARNING: Unable to load code page translation table
1757
09-14-2022 03:18 AM
MariameYasser
Hello all! I am facing an issue with running my code using the arcpy module in python using ArcGIS Pro. After incrementally commenting lines I discovered that the error arises with the arcpy.analysis.Buffer command. I tried following this link: https://support.esri.com/en/technical-article/000002929  to solve my issue by assigning a different folder to the TEMP but it didn't work. I moved the code to a different device and it works just fine, the problem is only in 1 PC but I need to use this specific PC. Once I remove the line of code the rest of the code works fine. I also attached below the code I am using, I tried changing parameters value using other feature classes nothing works. But when I use the tool on ArcGIS it works just fine.
Tags (3)
RiccardoKlinger
Ciurrently we share a similar problem. During the build of a network dataset we have faced a similar error message:
WARNING: Unable to load code page translation table c:\program files\arcgis\pro\\locale\codepage\0.txt.
Code page conversion is off for writing data into files.
Code page conversion is off for reading data from files.
