Version 3.5 "move" tool fails after a few moves
349
5
2 weeks ago
Mark_Eygenhuysen
Does anyone know why the move command dogs out after a couple of moves? This also affects the "edit vertices" command as well as split interactively.  Probably others but these ones are getting cumbersome.  I'm using v3.50.  I've lost count as to how many times I've had to close and re-open a project just to get one these commands to work again.
ThomasHoman
3.5.5 is current patch for 3.5.x any way you can move off the .0 release?
Mark_Eygenhuysen
No, the client is using the 3.5.0 version.
JenniferCadkin
Hi @Mark_Eygenhuysen  Can you provide more details about what is happening, maybe some repro steps and screenshots?
RTPL_AU
Honored Contributor
Hi @JenniferCadkin
In the 3.5.5 release notes I did not see anything around performance fixes or addressing the slow-down 3.5.x experiences over time as an instance is kept open.
Is this something you might know they looked at for 3.5.5?
Unsure if this is what Mark is seeing - in a long editing session things like moves and vertex editing, tracing a new feature along another with dense vertices, etc exacerbated the slowdown issue and I am now in a habit of restarting Pro every hour or so (avoids this issue and reduces likelihood of encountering the freeze on copy issue).
My experience with 3.5.4 shows that @Mark_Eygenhuysen is unlikely to see an improvement in behaviour going to 3.5.4
@Mark_Eygenhuysen  As you are stuck with 3.5.0 as long as your client is on it, make sure to avoid BUG-000176644 related to SQL expression based filters and selections in FGDB data. It can mess up your day if you run a calculation and it updates the entire dataset instead of just the selection you thought you had.
DuncanHornby
MVP Notable Contributor
You don't say how you are using arcpro. I have found the rotate edit tool can blow up arcpro when I'm accessing arcpro via a remote desktop connection. It appears to be specific to that machine and makes me wonder if it is a graphic driver issue. As Jennifer above says, we need way more detail to help.
