ArcGIS Pro won't allow splitting without a selection after November 2025 update
930
11-20-2025 11:53 AM
CarolynScholl4
After the latest (November 2025) update, when I try to split a polygon with the "Allow splitting  without a selection" box checked, I get the following error message, "Splitting features failed.
A polygon cut operation could not classify all parts of the polygon as left or right of the cutting line."
If I select a polygon and try to split it with the  "Allow splitting  without a selection" box checked,  I get the same error. I can only split the polygon without the box checked and polygon selected.
CarolynScholl4
Yep, that was the problem. I thought they were, but the map frame was NAD 1983 California and my feature class was just NAD 1983. My bad!
JenniferCadkin
Hi @CarolynScholl4  Can you provide a screenshot of the polygon and the Split line you are sketching?  Is the polygon data projected on the fly?
DanPatterson
MVP Esteemed Contributor
version of Pro?  are the map and layer in the same coordinate system?
BUG-000172550 for ArcGIS Pro
... sort of retired...
CarolynScholl4
DanPatterson
perhaps you could mark my post as the Accepted solution then
