Using a Join w/ Excel
1314
04-21-2022 09:55 AM
Labels (3)
mkhenson
Greetings everyone....I am using a join (excel) to connect to some points in my arcgis pro map.  I have gone in to the excel spreadsheet and changed the name of one of the headings.  When I re-open my gis map, that heading has not changed.  What do I do?  Remove the join and reconnect?  Thanks for any input you can give me.
MKH
DanPatterson
remove the excel file.  Fix it up, then use the Excel To Table file to make a geodatabase table.  do the join with it
... sort of retired...
mkhenson
problem is that this spreadsheet will be constantly changing.  Probably not the headings, but the contents within the cells will.
Robert_LeClair
Esri Esteemed Contributor
Another idea since you have to use the Excel file as it updates regularly is create a model in ModelBuilder that exports to a fGBD (or eGDB) table, perform the join  and work with the data daily.  In fact you can schedule the model to run every period of time that you wish - daily, once a week, every six hours, etc.  Then you'd be working with (somewhat) near real time updates.
