Distance Accumulation Raster Mask Missing Polygons
875
04-22-2022 08:44 AM
aaroncarr166
I have a points dataset of river/stream access points and a polygon dataset of river/stream areas buffered 100 meters (both across Pennsylvania).  I want to calculate the distance of each point under the mask of the buffered streams/rivers.  When I run this tool, it produces a raster successfully but does not produce cells under the polygons.  This happens under the polygons that do not have an intersecting access point.  I've run the tool without issue with a roads polyline dataset, so I am not sure what the issue is but I am hoping it's a simple fix.
Any advice appreciated!
