I have a report that I use when I am creating As-Builts inside of ArcGIS Pro. I use a summary statistic to calculate the sum footage of the conduit.
The statistic is setup like this:
It has been discovered that the Conduit Footage needs to be multiplied by another field 'Conduit # Placed' which says how many ducts were placed. This would get a better accuracy of the total amount of footage of duct that has been placed.
For each feature the 'Conduit Footage' would have to be multiplied by the 'Conduit # Placed' and then the total sum length would have to be taken.
I was wanting to try and write the code in arcade on the report so it would still follow the grouping of the report.
I could create another field in the feature itself that would do the multiplication, but I was seeing if there was a way to do it in the report itself.
Hi @JaronJensen7!
The reporting team is actively working on support Arcade expressions in reports in Pro 3.3. Stay tuned!
Alycia
Hi @JaronJensen7!
Alycia
