Unique Values with Graduated symbology
797
03-31-2024 06:46 AM
Labels (2)
ReaCamileMaglaya
Hello to all of you.
I'm having trouble illustrating the water ecosystem using a variety of colours while maintaining the feature where the circle size indicates the concentration at a different range. I can use "vary symbology by attribute" to adjust the circle's size, but it only gives me four values. Is there a method for me to display the aquatic ecosystem in colour while varying the circle sizes in a range that corresponds to what graduated symbology will produce? Will this one work with arcade symbology?
I will be truly grateful for all of your responses. Thank you
Attached photos are where I am right now
I have read and seen some solution with copying the feature and changing its symbology, but it doesn't look on my map since I only have a few points. Please see photo below
Thank you 🙂
