Undo a field calculation in ArcPro
14922
12
10-27-2016 06:59 AM
RichardHughes2
How is it possible to undo a field calculation in ArcGIS Pro?  In ArcMap the edit session allow for undo, in ArcPro what is the solution?  There is a solution for this right?  Otherwise field calculations are not safe.
Tags (1)
KoryKramer
Esri Esteemed Contributor
At ArcGIS Pro 2.7 an option was added to have Enable Undo toggled on by default: Geoprocessing options—ArcGIS Pro | Documentation
LCTechLogin
How do you keep this toggle on?  I'm having to click it on each time - and I would rather just have it on permanently.
Signature for a badge - a fair trade.
KoryKramer
Go to Geoprocessing Options:
Read more about that setting and considerations to keep in mind here: https://pro.arcgis.com/en/pro-app/latest/help/analysis/geoprocessing/basics/geoprocessing-in-an-edit...
