Undelete rows in feature layer editable by multiple users that I saved
1018
03-21-2024 06:11 AM
BonnieHu
I use ArcGIS Pro 3.2.2 and mistakenly saved a web map after deleting rows from a feature layer while trying to use a subset of the rows to make a new feature layer. Is there a way to get all the deleted data back? I feel like I have destroyed my colleagues' hard work. My user type is GIS Professional Advanced if that matters.
jcarlson
If all you did was save the map, it may be okay. If you saved your edits, you may be out of luck.
Where is the data stored? If you're using an Enterprise GeoDatabase with archiving enabled, you could recover deleted features.
- Josh Carlson
Kendall County GIS
BonnieHu
Thanks for the response. Turns out the data was backed up so it shouldn't be too hard putting it back in. Definitely a learning experience!
