Unable to select attributes from imported dataset
2302
6
09-08-2021 06:33 AM
MartinColling1
I am trying to clip/extract from the following data set available via the Living Atlas : Parishes and Non Civil Parished Areas (December 2017) Boundaries in England and Wales
However, when the data layer is imported none of the shapes are selectable and I am unable to even query each parish. Is there something I am missing in the selection options?
Cheers in advance
David_Brooks
MVP Regular Contributor
@dmartin , can you provide a link to the service url you are using and i can take a look. or just a link to the item in living atlas
David
..Maps with no limits..
David_Brooks
David
MartinColling1
Thanks Brooks, turns out all data layers provided by the UK ONS are Map files. There lies my problem, thanks for your time on such a trivial issue.
David_Brooks
@MartinColling1 , no problem, but if you're just after the data, then you can download it from here:
https://osdatahub.os.uk/downloads/open
The Boundary Line dataset contains Parishes, Wards, Local Authorities, Counties, etc etc. Fill yer boots!
David
MartinColling1
Thanks for pointing me in the right direction. Got them now, cheers!
DavidPike
MVP Notable Contributor
I've tested it and seems to be OK.  How did ou add the layers? 'Map' Tab --> 'Add Data' --> search living atlas and add data.
It may be something as simple as needing to close and reopen arcgis pro and start a new project.
MartinColling1
David you star, had already restarted Pro once but a system restart seems to have done the trick. Cheers
