Hey @cmorgan4810
I was curious if you've restarted your Pro? It may be a cached issue, I've been running into that quite a bit and a restart fixed it for me!
Cody
Does this occur across all of your ArcGIS Pro projects?
Could you take a look at the following to see if it is helpful? https://support.esri.com/en-us/knowledge-base/error-requested-operation-could-not-be-completed-00002...
I've run into that before. Sometimes restarting the application or moya app sassa 350 reloading the layer helps clear the issue. Have you tried that yet.
