Change to FeatureSharingDraft tags property after upgrade ArcGIS Pro to 3.4
2036
6
11-13-2024 08:56 AM
Jamie_Leitch_CNF
I just upgraded my desktop machine to ArcGIS Pro 3.4 from 3.3.x, and noticed a change to the FeatureSharingDraft class tags property.  After updating my cloned python environment, I was getting an error in one of my python scripts on the last line in this snippet:
sharing_draft = mp.getWebLayerSharingDraft("HOSTING_SERVER", "FEATURE", sd_fs_name)
sharing_draft.summary = "my summary"
sharing_draft.tags = ["tag1", "tag2"]
sharing_draft.exportToSDDraft(sddraft)
The error was: Error exporting SD Draft: 'list' object has no attribute '_validateParameters'
When Pro 3.3.x was installed this error did not occur.  Turns out it was the tags property - it cannot be a list, it must be a string with tags separated by a comma or semi-colon.  Its strange that this property was always specified in the documentation to be a string, but I was using a list without error.
Just posting this in case anyone else has a similar issue.
DavidColey
MVP Frequent Contributor
Definitely thank you for this @Jamie_Leitch_CNF  - I've been using this method since 1.x (or ever since they created the arcpy sharing module) to create sddrafts, stage the sd file, and upload same in order to keep our weekly Enterprise hosted feature layers current....
DavidColey
Here's how I've always done this in the Python IDLE if it helps anyone:
# Import system modules
import sys, os, arcpy, time, smtplib
from arcpy import env
from datetime import timedelta
# Local variables...
message = ""
current_time = time.asctime()
starting_time = time.time()
arcpy.SetLogHistory(False)
env.configKeyword= "DEFAULTS"
env.overwriteOutput = True
def stageSDDraft(mp,lyrName,summary,lyrs,descript,folder,tags,sdfolder):
    sddraft_out = "C:/ArcProProjects3x/PortalUpdates/" + sdfolder + "/" + lyrName + ".sddraft"
    draft = mp.getWebLayerSharingDraft("HOSTING_SERVER", "FEATURE", lyrName, lyrs)
    draft.portalFolder = folder
    draft.tags = tags
    ##draft.allowExporting = True
    draft.summary = summary
    draft.description = descript
    draft.overwriteExistingService = True
    draft.exportToSDDraft(sddraft_out)
    return
try:
    portal = arcpy.SignInToPortal("https://webserver.ourorg.net/portal", "myUserName", "MyPassword")
    aprx = arcpy.mp.ArcGISProject('C:/ArcProProjects3x/PortalUpdates/PortalUpdates.aprx')
    for m in aprx.listMaps("Trans Layers"):
        print("Map: " + m.name)
        for lyr in m.listLayers():
            if lyr.name == 'Thoroughfare':
                lyrList = []
                lyrList.append(m.listLayers(lyr.name)[0])
                print(lyr.name)
                stageSDDraft(m, lyr.name, "The Thoroughfare layer contains existing and planned roadways for Sarasota County, supporting a variety of transportation, evacuation and transportation planning efforts.",lyrList,
                             "The Thoroughfare layer contains existing and planned roadways for Sarasota County, supporting a variety of transportation, evacuation and transportation planning efforts",
                             "TransportationLayers","Transportation,Planning,Services,Safety","Transportation")
                print(lyr.name + " Draft Created")
                arcpy.StageService_server('C:/ArcProProjects3x/PortalUpdates/Transportation/' + lyr.name + '.sddraft', 'C:/ArcProProjects3x/PortalUpdates/Transportation/' + lyr.name + '.sd')
                print(lyr.name + " Service Staged")
                arcpy.UploadServiceDefinition_server('C:/ArcProProjects3x/PortalUpdates/Transportation/' + lyr.name + '.sd', 'My Hosted Services', "","","","","","OVERRIDE_DEFINITION","SHARE_ONLINE","PUBLIC",
                                                     "SHARE_ORGANIZATION","Transportation Layers Group")
                print(lyr.name + " Service Uploaded")
                message = message + "\n" + "1. " + (lyr.name) + " Service Uploaded"
So it looks like I am going to have to adjust my tags string here in the stageSDDraft:
to
"Transportation", "Planning", "Services", "Safety"
or to
["Transportation", "Planning", "Services", "Safety"]
@Jamie_Leitch_CNF
Jamie_Leitch_CNF
@DavidColey actually, this: ["Transportation", "Planning", "Services", "Safety"] would fail.  It should be:
DavidColey
So basically like I have the tags parameter currently formatted.  Thanks @Jamie_Leitch_CNF
DavidColey
So you may find this interesting @Jamie_Leitch_CNF  - when I tried to overwrite my layer like I detailed above, the
failed with five 9's - 99999 something unexpected....
Turns out that where I am specifying the group to be shared with, "Transportation Layers Group" in my case  I now need to specify it as a list:
["Transportation Layers Group" ]
Once I did that, the Upload Service Definition method works
calin_gi
This actually breaks backwards compatibility, because tags are listed in an array in the item JSON, so when migrating items with arcpy, it will fail.
