Unable to Adjust Layer Order in ArcGIS Pro 3.4.2
5829
21
02-07-2025 08:55 AM
YingboDong
Hello everyone,
I am currently facing an issue where I am unable to adjust the layer order in ArcGIS Pro. Here's a brief overview of the situation:
  • I am working in the Map tab and have already clicked on the Drawing Order button to enable layer order adjustments.
  • Despite this, I am unable to drag layers up or down in the Contents pane to adjust their order.
  • I also tried creating a new project, but the problem persists, and I still cannot reorder the layers.
  • My ArcGIS Pro version is 3.4.2.
If anyone has encountered a similar issue or has a solution for this, I would greatly appreciate your help. Thank you in advance!
HelenCooper
Thanks @YingboDong , yes that works, but is not great for my productivity!  Thank you.
ScottTillotson1
Only recently found I had this problem, running it on a PC with dual monitors, what worked for me is actually undocking the contents pane dragging it to the other monitor. It then allows me to move the layers. Drag it back again redock it and carry on.
