Trying to create a orthomosaic from DJI Drone Images
352
04-22-2024 03:08 PM
villamayor1
Screenshot 2024-04-22 180635.pngScreenshot 2024-04-22 180659.pngScreenshot 2024-04-22 180723.pngI am fairly new to ArcGIS Pro. I have taken photos of a salt flat and am looking to create an orthomosaic. After following some tutorials on youtube and quite a while of processing time (over 270 HD images), I am getting a very rough orthomosaic. What are some things I could try doing?
ThomasHoman
Occasional Contributor III
First off, may I ask a question? was the image collection done under some sort of flight controller software like esri's offerings https://www.esri.com/en-us/arcgis/products/arcgis-reality/platform/drone-mapping ? The bounding boxes appear to have variable overlap that could through things off. The mission planning and flight execution modules are pretty good.
Unfortunately ArcGIS Pro does not have the modules for generating orthophotos. That is their Drone2Map product https://www.esri.com/en-us/arcgis/products/arcgis-drone2map/overview
If you don't have access to a D2M license you could try some open source products that can be easily searched for.
Cheers!
Tom
villamayor1
Hi Tom!
No, I just took the photos manually :/. I will try the resources you
provided. Thank you for the quick reply!
-Antonio
