Trouble Creating XY Point Feature From Imported Table
6199
11
01-04-2024 02:08 PM
BRobbins
Hi all,
I've been encountering an issue preventing me from creating an X-Y Point features from an imported .xlsx table.
Using ArcGIS Pro 3.2.1 I've imported a .xlsx file as a standalone table into my project and am able to successfully open it and confirm that all the expected is there.
My problem has arisen when I attempt to create points from the table using the "XY to Point" geoprocessing tool. The Geoprocessing tab on the right side of the project window only seems to recognize one column from my table (AutoNumberID) and none of the other fields.
picture of ArcGIS problem.jpgpicture of ArcGIS problem.jpg *Note: The coordinate system shown in the Geoprocessing tab (GCS_WGS_1984) is simply the default. I normally switch it to the project's PCS (NAD 1983 UTM Zone 10N) but didn't go back and retake the screen capture.
I've tried converting the table to .csv files and uploading those and creating new, abbreviated, tables with only the two Northing and Easting columns, but I encounter the same problem.
Frankly, at this point, I'm pretty stumped.
Any thoughts or suggestions?
BRobbins
I was able to create the XY Point feature after converting the Excel file to .csv, so initial issue solved; but I'm still unsure of why it didn't initially work with the .xlsx file.
It was an Excel Workbook, but it only had one sheet, and even if it had more, I've had similar files work in the past....
DanPatterson
MVP Esteemed Contributor
Without being able to see what the coordinates are,...
if they are left justified, then it is text
... sort of retired...
BRobbins
Some examples of coordinates in the table would be
214455.096 (COORD_NORTH column), 661601.852 (COORD_EAST column)
and
207013.59 (COORD_NORTH column), 692608.46 (COORD_EAST column).
Faiez
DanPatterson
If the numbers in the table are right justified, then they are numbers and not a text representation of numbers
BRobbins
I experimented with changing the cell justifications as well as formatting them all as both Text and General, to no avail.
The issue was resolved by converting the file to .csv, but I'm still not sure why the initial .xlsx file wouldn't work.
JoannaWhittier
As DanPatterson suggested, it may be that your fields in the excel table are still not numeric. General format doesn't always work. Whenever I have had this issue, I had to format the XY fields as numeric. Or just do as you did and convert to .csv.
Faiez
Hi!
Field names should not contain spaces.
Best,
Faiez
BRobbins
Ah! Good catch. I don't believe it was my original problem, but it was worth correcting.
Faiez
Hi!
Good luck.
Best,
Faiez
