Traverse tool not accepting Direction
6469
16
11-21-2024 07:25 AM
GISUser74305830
I'm entering in survey calls into the Traverse tool and I'm running into an issue where the Direction I enter doesn't take and gets changed to the direction of the previous call. It gets preceded by an * which, according to the documentation, indicates it is tangent to the previous direction. I'm not a super-experienced COGO user, but not sure what's going on.
jcarlson
Can you share the text of the description, or the bearing you're *trying* to enter?
- Josh Carlson
Kendall County GIS
GISUser74305830
Sure.
  • Call 13: N89-18-12W, distance of 1,133.27
  • Call 14: N89-17-59W, distance of 2,270.91
However, when I do that, Call 14 gets readjusted to: *N89-18-12W, distance of 2,270.91.
The distance is fine, but the bearing is not.
jcarlson
Odd. I can't replicate that here, but I'm not on the latest version of Pro. (2.2 over here.) Perhaps @SenecaFrancis  suggests, it has something to do with the software. What version are you on?
- Josh Carlson
Kendall County GIS
GISUser74305830
3.4 here.
SenecaFrancis
The traverse tool has been acting weird after the pro update. Usually when the * happens after I enter a direction I have to delete that row and inset a new one to get it take what I enter.
GISUser74305830
By the way, I tried just deleting those calls and entering new ones .... same results
HeatherWidlund
Having the same issue at version 3.4. I agree 3.4 has been buggy, lots of crashes and "read-only" projects on opening.
Markbe_utco
Experiencing the same issue with both curves and lines within the traverse tool.
Trying to enter:
  • N 90-00-00 W  1.75 ft
  • N 89-50-08 W  211.81
Traverse tool changes it to:
  • N 90-00-00 W  1.75ft
  • *N 90-00-00 W  211.81ft
With the * denoting that the line segment has been changed to, in this case, extend the same bearing
This is a 10 minute difference!  What gives?
RyanXiong559
Hello,
I'm also noticing that this issue when entering direction for a given line and ArcGIS Pro adjust it even when deleting the row. Also, I'm using 3.4 as well.
