I'm entering in survey calls into the Traverse tool and I'm running into an issue where the Direction I enter doesn't take and gets changed to the direction of the previous call. It gets preceded by an * which, according to the documentation, indicates it is tangent to the previous direction. I'm not a super-experienced COGO user, but not sure what's going on.
Can you share the text of the description, or the bearing you're *trying* to enter?
Sure.
However, when I do that, Call 14 gets readjusted to: *N89-18-12W, distance of 2,270.91.
The distance is fine, but the bearing is not.
Odd. I can't replicate that here, but I'm not on the latest version of Pro. (2.2 over here.) Perhaps @SenecaFrancis suggests, it has something to do with the software. What version are you on?
The traverse tool has been acting weird after the pro update. Usually when the * happens after I enter a direction I have to delete that row and inset a new one to get it take what I enter.
By the way, I tried just deleting those calls and entering new ones .... same results
Having the same issue at version 3.4. I agree 3.4 has been buggy, lots of crashes and "read-only" projects on opening.
Experiencing the same issue with both curves and lines within the traverse tool.
Trying to enter:
Traverse tool changes it to:
With the * denoting that the line segment has been changed to, in this case, extend the same bearing
This is a 10 minute difference! What gives?
Hello,
I'm also noticing that this issue when entering direction for a given line and ArcGIS Pro adjust it even when deleting the row. Also, I'm using 3.4 as well.
