Trace lines and put vertexes on intermediate points
1728
10-18-2021 10:17 PM
BrianOberdorf
I am a relatively new user to ArcPro and GIS generally.  I want to create a polyline that following along the frontage of several lot boundaries for example.  I recalled a colleague saying in Arc software (might have been ArcMap back then) you could select two points and the software would automatically create the line between and add vertex points at intersections along the alignment.   For example if you wanted to pick the front boundary between say 10 lots that go around a curve, you could select the start and end and the software would pick the shortest path and create a line following the curve.
I am not having any luck finding this feature (if it exists) in the software or googling, perhaps because I am not sure what it is called.  Any direction on this would be appreciated.
Thanks
JohannesLindner
