Tips for debugging Arcade scripts in VSCode/Node.js
2030
03-11-2022 05:41 AM
Bud
Legendary Contributor
What are some tips/tricks for debugging Arcade scripts in VS Code/Node.js?
(assuming that the Arcade script is fairly vanilla -- as in, it doesn't use many Arcade-specific functions  that need to be stripped-out)
For example, Arcade uses console(), whereas VS Code/Node.js uses console.log().
  • Solution:
    In VS Code, put this line at the top of the script:
    console = Object.assign(console.log, console);
  • That will assign console.log() to console(). Which means I can use the console() script in both programs -- without constantly doing "find and replace" on .log.
  • Note: Only use that line in VS Code; it won't work in Arcade (and isn't needed in Arcade).
Any other ideas?
(I'm a novice, so it's possible the console.log() thing is wonky...I'm just trying to learn, and not get too frustrated while I'm at it 🙂
Related: Idea: Arcade Extension for Visual Studio Code
jcarlson
Personally, I almost always keep one of these two things up in a tab:
  1. The Arcade Playground
  2. A "Test Space" dashboard pre-loaded with all sorts of datasets, widgets, and Data Expressions
As I work on a script in VSCode, I routinely copy it into one of these test spaces to get feedback. It's not perfect, but it works well enough.
- Josh Carlson
Kendall County GIS
Bud
By the way, the keyboard shortcut for auto-formatting code in VS Code is: Shift + Alt + F.
How do you format code in Visual Studio Code (VSCode)?
