tile package (increasing size)
2541
02-14-2022 09:48 AM
BenjaminvonKorff
When creating a tile package, I am finding that the size appears to decrease unless the highest resolution extents are chosen, where the file size can actually greatly increases beyond that of the original image. Is this typical for tile packages, and is there a way to allow for higher resolution extents (closer to 24 on a scale from 1-24) while keeping the file size from increasing?
Tags (3)
DanPatterson
MVP Esteemed Contributor
what type of tile package? map, vector, mobile?
What options are you using with the data you are packaging, for instance, there is a lot that can be changed for
Create Map Tile Package (Data Management)—ArcGIS Pro | Documentation
... sort of retired...
BenjaminvonKorff
Thank you so much for your response! The tile package (.tpkx) is of a JP2 raster. I am running Manage Tile Cache (using Input ArcGIS Online as the tiling scheme), and then Export Tile Cache to create the .tpkx.
DanPatterson
There are many parameters available in the tool that may have an impact on the file sizes.
Manage Tile Cache (Data Management)—ArcGIS Pro | Documentation
The first two paragraphs are also of interest as well.  So checking out the "optional" parameters may be worth exploring.
