The difference between polygons
10914
13
04-29-2020 10:22 AM
MauriceMitchell
I have to separate polygon layers, layer 1 and layer 2. The polygons in layer 2 don't completely cover the polygons in layer 1, therefore, I'd like to create a layer 3 that are polygons that aren't overlapped. Also, I'm using ArcGIS Pro 2.4 if that matters.
Town_ofCBS_GIS
thank you!! this did exactly what i needed it to.
MauriceMitchell
Thanks all, I think Erase would be the most useful tool. I will try the others, of course, in order to gain the most knowledge out of the situation.
AndresCastillo
If you have two polygons, 'A' and B', run the tabulate intersection tool.
Suppose 'A' has zone fields you want to summarize with.
The result will give you an output table that has the percent of the zone field in A that is covered with B.
you can then join this output table back to the A feature class, keeping all target features, and sort on the joined object id to see all of the records where the joined attributes are null (i.e. null objectid's).
This will tell you with A polygons had 0 coverage from the B polygons.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/analysis/tabulate-intersection.htm
AndresCastillo
PostGIS has a similar tool:
https://postgis.net/docs/ST_Difference.html
