The calculation result of Area Solar Radiation is wrong, the values are approximated in a grid.
1672
10-30-2021 08:58 AM
Labels (2)
久米俊郎
I added the height of the building (raster) to the DEM to create a DSM.
 I input the DSM to Area solar radiation in Spatial Analyst and calculated the solar radiation, but the results were strange.
The values were approximated in a grid pattern.
 Incidentally, I used the default values for the parameters of Area solar radiation.
When I calculated only the height of the buildings, we did not see such a trend.
 If you have more information, please let me know!
久米俊郎
I checked again and found the same error when calculating solar radiation using only the DEM. This means that there was a problem with the DEM itself. I was using resample to match the cell size of the DEM to the cell size of the building raster, and the resampling_type of resample was NEAREST, which caused the problem. NEAREST is not suitable for continuous data. The problem was solved by using CUBIC, which is suitable for continuous data.
SteveLynch
When you added the height raster:
- does it have the same cellsize as the DEM?
- and the same spatial reference?
- did you set SnapRaster=DEM when you added?
久米俊郎
Thanks for the advice!
 does it have the same cellsize as the DEM?-Yes
- and the same spatial reference?-Yes
- did you set SnapRaster=DEM when you added?-I used the raster calculator, but I could not set snap raster there.
久米俊郎
