The AddLocations and Solve functions in the NA module cannot run consecutively
291
05-07-2022 01:52 AM
圈圈
New Contributor III
I am creating a Python script to work with ArcGIS Pro. When I used the AddLocations and Solve functions in the NA module continuously, I found that only the former function worked and the latter function ran with an ERROR (ERROR 000840: this value is not a network analysis layer). The same thing happens when I change the order of AddLocations and Solve.
In the image above, the Solve function works, but the AddLocations function fails.
In addition, I found that this code runs correctly in Pro's native Python window, but fails when it is made into a geoprocessing tool.
Can any master please tell me why
圈圈
New Contributor III
I've found out why.
When the second function passes in the network analysis layer "路径", the program recognizes a sublayer of the network analysis layer that is also named "路径".
