Tables showing only selected records refresh/reset needlessly when I change selection in another table
1642
06-08-2023 07:42 AM
ColeSutton11
I've noticed when I have multiple tables open at once, let's just say say two for example, and Table 1 is set to Show Selected Records, then whenever I modify* the selection in the Table 2, Table 1 automatically refreshes and resets back to the top. This is quite frustrating, as constantly lose my place in Table 1 and have to scroll back to where I was.
*By modify the selection, I mean any sort of clicking on rows in Table 2, or by clicking the buttons for "Clear" or "Switch" selection. The only unaffected method I can tell: Modifying the selection of Table 2 using Select by Attributes does not seem to cause this automatic refresh of the Table 1.
Would be nice if this behavior would be fixed/prevented. Or perhaps there's some option I don't know of, where I can toggle to prevent the table refresh/reset? Any ideas?
Otherwise I suppose a workaround is to make a new layer from my selection in Table 1, and then I could open that layer's table and Show All Records, instead of Show Selected Records.
BrianBulla
Honored Contributor
This is not happening for me.  Regardless what I do, table 1 for me always stays selected and is never reverted to an state other than what I leave it at.
I am using Pro 2.9.
AlyciaRajendran_esri
Hello! This was a bug we fixed in Pro 2.5. What version are you currently using?
Thanks!
- Alycia
ColeSutton11
I'm in version 3.1.2
