Summarize within (analysis tools)
641
10-18-2019 07:37 AM
zahraGhaffari1
I need to use Summarize within tool to calculate the sum of area of buildings within each polygons. These polygins are  buffers around each building, which means that they overlap eachother. The tool run for couple of hours and then it fails and shows the general error of 99999.
Here is how I set the parameter: Input polygons: BuildingBuffer ; Input Summary feature: Building footprint ; summary fields: area , sum ; shape units: square meter.
Any thought on this?
I saw that other users had similar problems but I didn't find a proper answer for it.
PS-- both layers are in the same projected coordinate system.
KoryKramer
Esri Community Moderator
