Stack Labels
3544
6
02-08-2022 05:41 AM
RhysLlewellyn
Hi
I'm using ArcGIS Pro 2.9.1 and trying to create a polygon label that stacks 3 fields on 3 lines.
Using the VBscript and Python languages (& vbCrLf& or + '\n' +), neither of the stacking codes produces more than a 2-line label.
The Stack parameters under the Fitting Strategy option are set to a max of 3 lines, minimum of 1 character and maximum of 24 characters.
Can anyone advise on a fix or workaround for this please?
Thanks
Rhys
Sean_Wray
try & vbnewline & to make your stack. Do not check stacking in the label properties.
RhysLlewellyn
Thanks Sean, but that seems to make no difference at the moment.
Sean_Wray
can you post a copy of the entire expression you are trying to use?
RhysLlewellyn
As follows:
[Sub_Comp] & vbnewline & [Species] & vbnewline & [Area]
also tried the more modern & vbCrLf& code too. Output shown below: initial character ('c' or 'b') should be on a separate line.
Sean_Wray
I am at a loss. What happens if you change the order of the stacking fields? This is just a guess.
JesseWickizer
I can't reproduce this with version 2.9.1. Are you able to share a map package with sample data to review all the settings you're using?
