Spyder IDE no longer works after upgrade to ArcGIS Pro 2.5
13654
35
02-08-2020 11:16 AM
JohnHuillery1
Error:
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-nbextension-script.py", line 6, in <module>
from notebook.nbextensions import main
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\notebook\__init__.py", line 25, in <module>
from .nbextensions import install_nbextension
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\notebook\nbextensions.py", line 28, in <module>
from ipython_genutils.py3compat import string_types, cast_unicode_py2
ModuleNotFoundError: No module named 'ipython_genutils.py3compat'
DEBUG menuinst_win32:__init__(199): Menu: name: 'Anaconda${PY_VER} ${PLATFORM}', prefix: 'C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3', env_name: 'arcgispro-py3', mode: 'user', used_mode: 'user'
DEBUG menuinst_win32:create(323): Shortcut cmd is C:\Users\JHUILL~1\AppData\Local\Temp\_MEI144042\pythonw.exe, args are ['C:\\Users\\JHUILL~1\\AppData\\Local\\Temp\\_MEI144042\\cwp.py', '"C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3"', '"C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\pythonw.exe"', '"C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\Scripts\\spyder-script.py"']
DEBUG menuinst_win32:create(323): Shortcut cmd is C:\Users\JHUILL~1\AppData\Local\Temp\_MEI144042\python.exe, args are ['C:\\Users\\JHUILL~1\\AppData\\Local\\Temp\\_MEI144042\\cwp.py', '"C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3"', '"C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\python.exe"', '"C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\Scripts\\spyder-script.py"', '--reset']
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\runpy.py", line 183, in _run_module_as_main
mod_name, mod_spec, code = _get_module_details(mod_name, _Error)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\runpy.py", line 109, in _get_module_details
__import__(pkg_name)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\__init__.py", line 3, in <module>
from . import (features, geoanalytics, geocoding, geometry,
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\features\__init__.py", line 28, in <module>
from . import enrich_data
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\features\enrich_data.py", line 10, in <module>
import arcgis.network as network
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\network\__init__.py", line 7, in <module>
from ._layer import NetworkLayer, NetworkDataset, ClosestFacilityLayer, ServiceAreaLayer, RouteLayer, NAJob
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\network\_layer.py", line 8, in <module>
from arcgis.mapping import MapImageLayer
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\mapping\__init__.py", line 8, in <module>
from ._types import WebMap, WebScene, MapImageLayer, MapImageLayerManager, VectorTileLayer, OfflineMapAreaManager, PackagingJob
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\mapping\_types.py", line 19, in <module>
from arcgis.widgets import MapView
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\widgets\__init__.py", line 2, in <module>
from arcgis.widgets._mapview import MapView
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\widgets\_mapview.py", line 15, in <module>
from ipywidgets import widgets
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\ipywidgets\__init__.py", line 25, in <module>
from .widgets import *
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\ipywidgets\widgets\__init__.py", line 4, in <module>
from .widget import Widget, CallbackDispatcher, register, widget_serialization
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\ipywidgets\widgets\widget.py", line 18, in <module>
from ipykernel.comm import Comm
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\ipykernel\comm\__init__.py", line 1, in <module>
from .manager import *
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\ipykernel\comm\manager.py", line 15, in <module>
from .comm import Comm
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\ipykernel\comm\comm.py", line 9, in <module>
from ipykernel.kernelbase import Kernel
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\ipykernel\kernelbase.py", line 19, in <module>
from jupyter_client.session import utcnow as now
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\jupyter_client\session.py", line 56, in <module>
from zmq.eventloop.ioloop import IOLoop
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\zmq\eventloop\__init__.py", line 3, in <module>
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\zmq\eventloop\ioloop.py", line 78, in <module>
while _IOLoop.configurable_default() is not _IOLoop:
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\tornado\ioloop.py", line 328, in configurable_default
from tornado.platform.asyncio import AsyncIOLoop
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\tornado\platform\asyncio.py", line 34, in <module>
asyncio.set_event_loop_policy(asyncio.WindowsSelectorEventLoopPolicy())
AttributeError: module 'asyncio' has no attribute 'WindowsSelectorEventLoopPolicy'
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-nbextension-script.py", line 10, in <module>
sys.exit(main())
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\jupyter_core\application.py", line 267, in launch_instance
return super(JupyterApp, cls).launch_instance(argv=argv, **kwargs)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\traitlets\config\application.py", line 664, in launch_instance
app.start()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\notebook\nbextensions.py", line 988, in start
super(NBExtensionApp, self).start()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\jupyter_core\application.py", line 256, in start
self.subapp.start()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\notebook\nbextensions.py", line 716, in start
self.install_extensions()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\notebook\nbextensions.py", line 695, in install_extensions
**kwargs
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\notebook\nbextensions.py", line 211, in install_nbextension_python
m, nbexts = _get_nbextension_metadata(module)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\notebook\nbextensions.py", line 1122, in _get_nbextension_metadata
m = import_item(module)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\traitlets\utils\importstring.py", line 42, in import_item
return __import__(parts[0])
sys.exit(main())
app.start()
self.subapp.start()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\notebook\nbextensions.py", line 896, in start
self.toggle_nbextension_python(self.extra_args[0])
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\notebook\nbextensions.py", line 872, in toggle_nbextension_python
logger=self.log)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\notebook\nbextensions.py", line 483, in enable_nbextension_python
logger=logger)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\notebook\nbextensions.py", line 380, in _set_nbextension_state_python
(arcgispro-py3) C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3>
DanDeegan
I have a clean install of windows and am trying spyder again. The newest version of Anaconda navigator shows spyder 4.0.1. But it will not update to it. It fails because of some jupyter thing.
I have tried doing it from conda in my environment and it fails with:
(arcgispro-py3-spyder) C:\windows\system32>conda install spyder=4.0.1
Collecting package metadata (current_repodata.json): done
Solving environment: failed with initial frozen solve. Retrying with flexible solve.
Solving environment: failed with repodata from current_repodata.json, will retry with next repodata source.
Collecting package metadata (repodata.json): done
SpecsConfigurationConflictError: Requested specs conflict with configured specs.
 requested specs:
 - spyder=4.0.1
 pinned specs:
 - jupyter_client==5.3.1
Use 'conda config --show-sources' to look for 'pinned_specs' and 'track_features'
configuration parameters. Pinned specs may also be defined in the file
DanPatterson_Retired
conda install spyder --no-pin
The jupyter thing is an issue that will be fixed from what I can gather in spyder 4.1 (which is due out this month and will update everything)
Nothing that I can find is broken in Pro with the version difference.
PS loving the new spyder
/blogs/dan_patterson/2019/12/12/spyder-4-the-python-ide-for-science
DanDeegan
Still can't install spyder 4.1+ on a cloned environment. I give up.
DanPatterson
MVP Esteemed Contributor
Anaconda navigator?
Did you clone the esri distribution? Navigator required modification to one of the scripts in order to get it to work.
If you used Navigator to do the clone or didn't run
in the
C:\Your_install_path\bin\Python\envs\arcgispro-py3 path in conda, I suspect something else is the issue
... sort of retired...
DryCreekEng
Im with you Dan Deegan‌. I have tried so many times and so many ways, and it just wont work. I gave up too. Dan Patterson‌ I tried everything you just suggested and it didn't work.
DanPatterson
Of course, you could just install in the base environment and not a clone if you are the administrator on your machine (that is what I do)
DryCreekEng
Hi Dan, let me introduce you to my rabbit holes.
1. I try to add Spyder to my base environment in ArcPro.  As you can see the highest version available is 3.3.6. I am up to date on all updates.
2. Go to Anaconda Navigator and try to install it in the base.
3. Try to install it from the Python Command Prompt (as administrator)
4.  Repeat above steps for cloned environment and get the same result.
DanPatterson
The problem seems to be Anaconda Navigator.  I stopped using it since you had to edit one of the scripts in order to get it to work.
  • I installed ArcGIS Pro 2.5
    • no upgrade, I never upgrade,
    • I remove and reinstall by downloading the exe and running the msi,
    • and I install in a folder without spaces eg. c:\arc_pro
  • I installed spyder using conda install spyder --no-pin
Been working fine,  No clue what the remote connection issue is
DryCreekEng
Hi Dan,
I uninstalled ArcPro and reinstalled it to c:\ArcPro as you recommend. Now when I open the Python Command Prompt it is still looking for the default "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3". When I change the directory to the new location "C:\ArcPro\bin\Python\envs\arcgispro-py3" I get the error below.  What do I need to do to change the default location?
Natalie
DanPatterson
Did you "activate your environment" ?
Managing environments — conda 4.8.3.post57+fb127b1c documentation
You appear to have some remnants of the previous installation
