Splitting a road (line segment) and maintaining attributes question
1134
7
09-02-2025 11:31 AM
JacobGeisler
I am sure there is a simple solution to this but I am drawing a blank... I am in the process of splitting a road (line segment) into two sections.  My issue is that when I split the road, the section to the north is maintaining attributes and the new section to the south is the new segment.  However, I would like this to be reversed (south needs to retain attributes and north needs to be the new segment).  Is there a way to set the parameters so I can choose which section retains attributes?  I know I can transfer attributes but the road is tied to several relates and it would just be much easier if I knew how to set the attribute retainment rule to the appropriate section.  Thank you!
SteveCole
Honored Contributor
I wonder if the course of action it takes is related to the line's direction (from/to nodes)..
Robert_LeClair
Esri Esteemed Contributor
I tested reversing the line direction followed by an interactive split and it seemed to do what you're looking to accomplish.  The interactive way to flip a line direction is as follows:  Reverse the direction of a polyline—ArcGIS Pro | Documentation
JacobGeisler
Thank you for the help.  I test this and it still didn't work for me.  The attributes were still retained on the south segment.  I may have done it wrong though.
JMutunga
@JacobGeisler  could you clarify if the desired result is to 'retain' just the ObjectID or all attributes?
JacobGeisler
My desired result is to retain most attributes, especially the name of the road.
JMutunga
Okay.
If you have Relationship Classes, I'd suggest this online Help about Setting Up Split Policy for Relationship Classes .
Otherwise, if you are working with Domains, you can use the Alter Domain geoprocessing tool to change to a policy that works for your scenario.
I am assuming you are not working with Location Referencing because special tools provided by the Extension manage splitting differently.
Jennifer_Parmeley
I feel like there's a place you can set split information. I, of course, cannot find it right now, but poke around in settings in editor and/or that layer. You'll find it when you least expect to.
