Unable to add LAS-file to mosaic dataset - ERROR 001159
240
09-05-2025 01:59 AM
mrPeppermint
Hi!
I have several point clouds as LAS-files that I would like to manage and serve through a mosaic dataset. I want to use the mosaic dataset as a library so that I can can find a LAS-file and download the "original" LAS-file.
When I try to add the raster though the "Add Rasters To Mosaic Dataset" tool i have the used the following options:
Raster type: LAS
Input data: File
Maximum cell size: 0,06
I computed statistics on the LAS-file and I have a point density of 0,015. This post recommended that I use four times the point density as a cell size.
When I run the geotool I get the following error:
ERROR 001159: The raster type could not be validated for reasons listed below. Please edit the properties of the raster type to ensure no required parameter is missing.
Failed to execute (AddRastersToMosaicDataset).
The docs say that I have to specify a cell size but the error message leads me to believe that the cell size is wrong or there is another parameter that is missing.
