Snow Plowing Optimization
1545
01-23-2024 10:21 AM
aprhyde11
I’ve been tasked with finding a way to optimize snow plow routes and be able to mark them as complete once they’re done. I’ve done some research and found I could use ArcGIS Velocity to possibly do this but it is a bit pricey. I’ve also seen the Network Analyst extension could help but I haven’t used that extension before.
All the posts I’ve seen have been pretty old I’d like to find an updated solution that doesn’t involve other companies and isn’t too pricey.
If the only solution is to have another company run it please give suggestions to that as well.
Thanks!
Robert_LeClair
Esri Esteemed Contributor
There is a Winter Weather Operations solution you can find here for response plans, snowplow feeds and winter weather operations.  May be worth a look.
