Show line dimensions while editing
5287
02-18-2021 10:46 AM
LonSharp
In ArcMap, while creating a feature (or reshaping), there is a display at the bottom of the map showing the measurements of the current line segment with length & direction.    Is there an equivalent in Pro?   I've checked under Options-Editing (and everywhere else I can think of) but do not see any option for this.
If it doesn't exist, it would certainly be a good enhancement for the future.
Scott_Harris
Hi @LonSharp You can turn on Dynamic Constraints to show segment direction (or deflection) and distance. It also works while reshaping. If you want to enter specific vales, you can hit TAB while sketching.
Turn it on at the bottom of the map:
Help topic:
https://pro.arcgis.com/en/pro-app/latest/help/editing/constrain-distance-for-a-segment.htm#ESRI_SECT...
-Scott
Scott_Harris
Help topic:
-Scott
LonSharp
I knew it would be somewhere obvious!   Many thanks Scott.
