Hello Community; It took awhile to find where this page is where one can post a question to the user community.
I am wanting to set the color of a label to the value that that variable contains in a graduated symbol color scheme for the data. Is this possible without fancy cryptic programming? Thanks; Dave
Is this the right place to ask questions on using Pro
No. I've moved it to the ArcGIS Pro community.
Don't view programming as 'cryptic'. It's more accessible than you think.
But yes, you can use Label Classes.
https://pro.arcgis.com/en/pro-app/latest/help/mapping/text/label-classes.htm
Add a label class then use the filtering on it for each value. This is typically used for different scale levels but if you have a few values for different colours it might not be too bad. As you get more values, the more classes you'll need, so using Arcade might be easier.
