Select multiply rasters by points
1007
05-04-2023 11:09 PM
JúliaMat
Hello! I have more than 500 rasters, and  I need to select only some of them according to the point layer. Please any idea how can i  do that? Thank you!
AndreasHall
You should be able to use Select Layer By Location (Data Management)—ArcGIS Pro | Documentation but it might require som preprocessing of your rasters, e.g. adding them to a mosaic dataset. This is not my field of expertise so I am afraid I cannot give you step-by-step instructions.
DavidPike
MVP Notable Contributor
There's various ways to do this but the simplest one-off solution would be what Andreas has suggested in building a Mosaic Dataset and using the footprints to select by location.
