Schedule Python scripts to run in ArcGIS Pro
11857
10
03-25-2022 01:04 PM
ABishop
Hello Everyone,
I have written some python scripts to automate some of the daily geoprocessing tasks.  I currently have these tasks set to automatically run in Windows task scheduler.  I recently learned that I can schedule these tasks in the ArcGIS Pro desktop environment.  I have a few test schedules created to run tonight.  My main question is, will the schedules run if the desktop isn't open?
Thanks in advance for any help!
Amanda Bishop, GISP
jcarlson
You can check in the task scheduler.
Or do you mean Pro being open or not? They should still run even if Pro is closed. It's been a while since I had an ArcGIS Pro specific script, but it ran every night without fail, and I didn't leave Pro up when I left at night.
- Josh Carlson
Kendall County GIS
DavidPike
MVP Notable Contributor
All I've seen Pro do is wrap the tool up into a script and enter into task scheduler, is there something different it can do?  Any scheduled tasks I have in Pro I just edit them in Task Scheduler to run when not logged in and as a service account etc.
ABishop
Yes, you are correct.  Since this is the first time I have tried scheduling something through ArcGIS Pro.  I did notice it is in my windows task scheduler too, but didn't know if I needed to leave ArcGIS Pro desktop open?
Amanda Bishop, GISP
jcarlson
- Josh Carlson
Kendall County GIS
ABishop
Thank you J!  I will just try closing Pro to see if it runs.  If not, I may need to modify the task in windows task scheduler.
Also, thank you  @DavidPike for your input.
Amanda Bishop, GISP
DavidPike
Yeh it's fine to have Pro closed, it's just like running an arcpy script.  Just look into the properties of the Task Scheduler job it creates and ensure everything is set as you need.
BillFox
If it fails, check to see if your security team blocks any required privileges in AD Group Policy.
For example:
Log on as a batch job
Log on as as a service
ABishop
Just a Monday update, my scheduled tasks ran properly Friday night and early this morning.  Thank you to everyone on this post for your help!
Amanda Bishop, GISP
Laura
by MVP Regular Contributor
How did you do this in Pro?
