Scatterplot with Non-Linear Trendline
2235
03-14-2023 12:32 PM
BenRomlein
Are there non-linear trend-line options for the scatter plot chart in ArcGIS Pro? I currently use Excel to plot data and I use the Power trendline option to generate an equation like y = mX ^ b with an associated R-squared. Is it possible to generate this trendline directly in ArcGIS Pro?
DanPatterson
MVP Esteemed Contributor
linear and logarithm axes are supported
Scatter plot—ArcGIS Pro | Documentation
you can transform the data yourself and use a linear axis if you the power trend to use and you don't like logarithmic or it doesn't fit
... sort of retired...
ChristopherAllen
HI @BenRomlein ,
Thanks for the question. Scatter plots currently only support linear trend lines, but adding other options is in our near-term plan.
Take care,
Chris
BenRomlein
Thanks for the replies. I was able to write a geoprocessing script to accomplish what I needed to do using scipy.optimize.curve_fit and matplotlib.pyplot
