Running Arcpy with a authorization code or virtual token
2266
03-16-2022 04:19 PM
Labels (3)
HéctorLeopoldoVenegasQuiñones
Hello, my name is Héctor, I'm seeking a college degree. I have an ArcGIS Pro license due to my university. And I need to run an image classification routine (Support Vector Machine classification) and it's going to take a few days to analyse a whole watershed. That is why I would like to run the python code of this process on the supercomputer at my university. But the supercomputer only runs Python codes and I cannot install ArcGIS Pro. Thus, Arcpy does not work on this computer because of its software dependency on ArcGIS Pro.
Just like Google Earth Engine where you can create a key to run any code without worrying about the virtual token (Authorization process). Is there a way to run Arcpy by not installing ArcGIS Pro?
I only want a way to leave my code running on a terminal, close my laptop and wait until the analyse is done.
Please, I have been reading a lot of websites but I cannot figure out a way to deal with this. I only want to run Python code in a terminal without worrying about leaving my laptop on.
Please I need help.
John_Spence
You can do it without ArcPy.
def getToken():
# Name: Function - getToken
# Purpose: Get's a authentication token from Portal.
if portal_URL[-1] == '/':
url = portal_URL + 'sharing/rest/generateToken'
referrer = portal_URL[0: -1]
else:
url = portal_URL + '/sharing/rest/generateToken'
values = {'f': 'json',
'username': portal_uName,
'password': base64.b64decode(portal_pWord),
'referer' : referrer,
'expiration' : '60'}
data = urllib.parse.urlencode(values).encode("utf-8")
req = urllib.request.Request(url)
response = None
while response is None:
try:
response = urllib.request.urlopen(req,data=data)
except:
pass
the_page = response.read()
#Garbage Collection with some house building
payload_json = the_page.decode('utf8')
payload_json = json.loads(payload_json)
data_token = payload_json['token']
return (data_token)
John_Spence
Oh....you can drop the base64 stuff I have in there. Had a security by obscurity moment.
AnthonyRyanEQL
arcpy is available to install from a conda package
John_Spence
Forgot to mention, you might not want to run Python on a supercomputer as it will probably take you a bit to tweak it for optimal performance and as you are likely aware, supercomputer time is limited. I would opt to go the route of C++ if my memory is correct on what is the most common language for it to run on. Stanford has been using Regent too.
